I’ve done the conversion not too hard to do except the re-wiring which I didn’t do, luckily my m8s dad is an electrician and he did it for me in about 20 mins for free. He showed me what he did and it isn’t really that hard.
All that needs doing is the split of the single bulbs wire (single optic lights have one bulb for high and low beam while the double optic has a bulb for each function). Finding out what each wire did was the hardest part just some trail and error till you get it right. Sidelights and indicator wires go straight on no problem.
But you got to make sure you buy the right bulbs for the lights as you cant use the old one; the headlamps from AndySpares only come with the sidelights and indicator bulbs.
The low beam bulb is HB3, and the high beam bulb is H7 (9005), get them from
http://www.powerbulbs.comwww.powerbulbs.com, I did and got ultra blue sidelights free with them. BTW they aren’t cheap!
Another thing you will need to change is the motors from the old lights and fit them onto the new lights not hard just clips in and out, this allows you to adjust the height of the beam, make sure that you line up the parts then clip them in otherwise the motor wont be connected properly and the lights wont be able to be adjusted. I found this out and it’s quite tricky.
One more thing that I can think of is you need to put an extra fuse in the fuse box, it goes where there is a picture of a light that looks like its on full beam. This prevents the low beam going out when you turn your full beam on.
Sorry for the long post I hope this helps.
Allan
