172 cup
Hi there.
Just fitted some rear pads on a mates megane scenic. Did the ns rear fine but when tightening the wheels bolts after doing the os rear i noticed the car was moving as the handbrake was off. On start up i was greeted with brake failure as i was pumping brakes!! maybe should have pumped before start up??
Anyway started up again, the fault had cleared and the handbrake was fine. I've done rear pads on a car before with a normal handbrake but this handbrake was electronic. Do you think the fault was just where i hadnt pumped the brakes before start up??
