Megane F7R
  Clio 182
What exactly is needed to do for this conversion? I have the option of a full megane lump with gearbox/loom/ecu etc or just a williams lump. I have a feeling ill have trouble finding a williams ecu, so would the megane engine be easier!?
Ta
Dan x
A williams would be easier due to the lack of re-wiring required, although the megane engine will fit you will require the engine loom from the megane and the ECU. You will then have to connect this up to the dash loom - personally i would stick to a williams conversion.
Ah ok..so with the williams lump, would I definately need the ecu? or would it be easier mix+ matching with my valver lump?
Just get the williams lump then get a cheap 1.8 ECU and have it chipped to 2ltr spec by Hillpower. You'll be able to use your 1.8 ECU as long as your careful if you need to wait on the 2ltr ECU.
