engine runs better when its at its optimal temperature not cooler, plus all it does is open earlier so the coolant runs around the radiator and takes longer to heat up, it will eventually get to the same temperatureQuote: Originally posted by matt the cat on 25 May 2004
the idea is that the engine runs cooler and therefore performs better.
Not sure it will reach the same temp - this assumption is based around the cooling system running at full capacity when maintaining normal temp. If there is sufficient cooling capacity within the system and the stat opens at a lower temp then the mean running temp will be lower. The less heat in the bay, the less heat transfer to the induced air, less heat in air, greater mass...greater mass etc etc.Quote: Originally posted by cliosportcraig on 25 May 2004
Agreed mate!Quote: Originally posted by cliosportcraig on 25 May 2004
Yes but the actual engine runs better at the right heat and aslong as you shield the air intake from the heat then it ultimatly runs better hotter, mean running temp will be slightly lower depending on driving time agreed
