Notice a few more of these popping up recently and I know there is RichMcc's guide but this is designed to let you know exactly what you need to change your dash over! And a little more additional information.
First off RichMcc's guide is located here... and id recommend using that as a starter.
http://www.cliosport.net/forum/showthread.php?t=175675
This was done on a Phase1 172 and some of the switches etc are slightly different on Phase2 172 (and other models). Id recommend reading up on that.
But what you will need to know is what type of LED's to get etc
First off the LED types and how many are needed...
Dash - surface mount x 10
Climate Control - Surface mount x28
Window switches - Through hole although you can use surface mount X3
Clock/Radio - Through hole again although you will have to use a resistor inline with the power to stop it from burning out! You can use surface mount but again will need a limiting resistor. X2
Locking button - Through hole although you can use surface mount X1
ESP - Through hole although you can use surface mount X1
Heater Button - Through hole although you can use surface mount X1
So that bring us to totals and what to buy! Id recommend the following
Surface Mount x 38 (minimum!)
http://www.rapidonline.com/Electron...rightness-surface-mount-LEDs/77736/kw/56-2998
Through Hole x 8 (depends if you use Surface mount in certain switches)
http://www.rapidonline.com/producti...leno=82277&catref=55-0072&kw=55-0072#techspec
NOTE! You will need to use resistor on some of these LED's. Yes it is possible to find a higher Voltage rating but you will pay a bit more. Plus BLUE LED's are only rated up to about a maximum of 3-4V. Im going to double check mine tomorrow so il post up the exact values of resistors if they are needed!
