Knocking sound driver side wheel
So i put on my 25mm hub- centric spacers and now theres a bad knocking sound, any ideas?
Cant get the wheel off again due to the locking nut pattern being crushed.
Went to tyre change place this morning, they got the lock nuts off, thankfully!
Brother is away to work in the car so will try looking at it later. Ill make sure the bolts are done up properly.
  Renault Clio MK4 RS
tbh id definitely check asap but like what others have said above, check the bolts are all torqued up properly and if the spacers are the problem for the moment being i would remove and leave off until you figure out the source of the problem. Think you would rather be driving a car that is safe with alloys hid in the arch than a car that could possibly lose a wheel and cause much more damage :) Hope you find the problem :)
