July Specials
This months special offers are as follows:
Headunit and Changer Packages
Kenwood 7177 Changer Package - £250 (normaally £299)
Panasonic CQRDP383 MP3/CD Headunit - £109
Sony CDXL280 CD Headunit - £85
JVC PK483 KSF483 + CHX550 Changer Package - £155
Alpine TDM7586RB+CHM630 (free remote) - £235
Amplifiers
Rockford Fosgate bd500.1 mono Amp (600 watts RMS @ 2ohms, 1000 watts RMS @ 1ohm) - £290
Rockford Fosgate G200S 200Watt 2 Channel Amp - £135
Rockford Fosgate G300S 300 Watt 2 Channel Amp - £175
Audiobahn A18001DT Class D mono Amp (1800watts RMS @ 1ohm, 1200Watts RMS @ 2ohms) - £599 (normally £700)
JBL GTO 2000 2 Channel 400 Watt Amp - £99
JBL GTO 4000 4 Channel 600 Watt Amp - £125
JBL GTO 6000 6 Channel Amp (can run your whole system) - £175
Sony XM255 2 Channel Amplifier - £60
Kenwood KAC819 mono Amplifier - £109
XS 900 Watt 4 Channel Amp - £99
Subwoofers
Kicker Comp 10" Sub (single 4ohm coil) - £50 each or 2 for £80
Audiobahn AW1251T 400 Watts RMS Sub (Flame Basket Basket, Dual 4ohm coils) - £75 each or 2 for £150
Audiobahn AW1500Q 15" 800 Watts RMS Sub (dual 4ohm coils - £165 - normally £235
Infinity 1220W 12" 1200Watt Sub - £80 or 2 for £150
Infinity Kappa 120.3SE 12" Sub - £90 each or 2 for £170
Resonant Engineering HC12 12" Sub (1200watts RMS,massive spec,weighs 22kilos) - £235
Alpine 1221D 12" Type R 1000 Watt Sub - £119
Other Items
10" and 12" Carpeted Sub Boxes (Ported or Sealed) - £26
8 Gauge Amplifier Wiring Kits - £10.50
Please call us on 07780 976769 or e-mail us on sales@evilice.co.uk if you have any enquiries.
All Cliosport forum users are eligable for up to 40% discounts on all Audiobahn and Zapco products
Russ
Evil I.C.E. Car Audio
www.evilice.co.uk
Sy - Im not sure we can still get hold of that headunit with it being the old model. However I will check with our suppliers for you just in case.
Soapsuds - Yes we stillhave some brochures. Did you PM me your address at any time.If not send it through to me and ill sort that out for you. Zapco have recently extended the reference range and most of the amps come with a free symbilink controller meaning that you save yourself loads of cash..bargain!!!
Charlie - The Comp subs are very good value and work well in small spaces too. They wont take too much power as they are essentially the same as the old Impulse series but at the end of the day you get Kicker quality for Sony money.
Russ
Ok then, what RMS is the Kicker Comp 10" Sub? and what amp would you recommend to go with it out of that list which could also be use to power a set of comps up front? Also would that sub need a sealed or ported box?
Cheers Phil
  S4 (320bhp) + Clio 16v
alright. my mate bird has got some crappy 8inch sub 4 her car and she needs a box. can u get hold of an 8inch box. i ordered 1 from a local place and they messed me about for about a month
The Comp subs are 125watts RMS as they are essentially the old impulse sub with a different cone design. Something like the JBL GTO 4000 would do the job there for a couple of those subs and it could also be used for powering components and 1 sub if you wanted it to as it is a4 channel amp.
Russ
Would the JBL GTO 4000 be good enought to power 1 Audiobahn AW1251T sub and a set of components? if so what components would you recommend to go in the front, without rear speakers?
The 4000 would power an AW1251 but you wouldnt be able to put anything else on the amp as you would need to wire a coil bridged to each side of the amp. Thats because it is a DVC sub. The Kicker is SVC which is why you can get away with it.
As far as components go. You would be best with a set of high efficiency ones. It alldepends on budget again but some reasonable options would be the Audiobahn ABC525Ts which are £109 or some Ground Zero Hydrogen 130s for £100 would sound nice off that amp. Another option would be a pair of the Alpine SPA-136s but they cost a bit more and are similar quality to the Audiobahns.
Russ
Sy - Unfortunately we cant get hold of that modelanymore. Our suppliers have got nearly all of the old models except that one which is abit annoying. Have you thought of going for one of the new range instead as they are virtually the same.
dj - We do the full range of Pioneer changer packages as the packs are set by Pioneer themselves.
Russ
evil ice, wot are the audiobahn abc 525q 5.25" components like? wot amp would you reccomend i use to power them?
would i get 40% off the components seeing as i am a member?
Cliojohn bought a set of those components and he is very happy with them. They definately need a decent amp though. Anything with 2x 60watts RMS or over will be fine. The Rockford Fosgate G200S would power them wel.
That speaker set is normally £130 but we sell them for £109 to Cliosport members.
Russ
What number did you try to ring? My mobile doesnt use an answerphone system.
What info do you need. I presume it was about the Zapco amps.
Russ
