Jamsport inlet manifold - any good?
ADS_V6
  Seat Leon
IM wondering that but people seem mixed views on this,some say do it others say no improvement
  BG Clio 182 FF
If I buy one mail order, rather than porting my own, will it still do the job? I'm guessing it won't be "matched" as such?
  RS RIP
worthwhile , the oem ones are quite bad. Check if your lower one has "RS" welded on it. If it does then it's fine and won't need doing as these are good from factory.. You can check this by using one of this dentist-mirrors to be able to look past/under the fuel-rail section. The upper one can always be done.
If the head is off get the head done and inlet done at the same time then you will notice the gains. The manifold on its own not so much.
