Is it worth it
hiya guys, first post here do be nice! :oops:, been recommended to this forum by rockport, im from the talk audio forum.
my boss has offered me his wifes 16v clio, dont know too much about it at the moment, but am going to see it on friday, this is what i know so far,
clio 1.8 16v, 1995/M, blue, around 60k miles
has some service history, the cambelt hasnt been changed (bargaining point i guess??)
he says its in very good condition, but will find this out for myself on friday when i look at it, ive heard really good things about the clio 16v.
what sort of price do you think i should be paying for this car assuming everythings ok and its in good condition?
thanks all
Adam
Quote: Originally posted by Clio_novice on 03 May 2003
Helllllooooooo i recon about a tenner.
Well maybe a bit more if its mint.LOL
WELCOME :p
TIGHT GIT!!!!!!!!!! at least 15 mate, cmon its lowish miles!!:p
Id print this off if I were you! This is the sum of almost my entire 16v/Williams knowledge that Ive put together for buyers like you!
Read the 1994 Cars & Car Conversions article on the Williams on the main Cliosport site: http://www.cliosport.net/articles/williams-2.asphttp://www.cliosport.net/articles/williams-2.asp. That outlines the Group A pedigree of the 16v - and its later homologated special edition: the Williams.
http://images.cardomain.com/member_img_b/286000-286999/286766_3_full.jpg
Despite this greatness, theyre expensive and time consuming cars - though not because there are any inherrent faults. Cared for cars will last very well, but those that have been repaired cheaply/not at all will cause problems. Its just a general hot hatch thing. Basically, you may be in deep water outside of buying from an enthusiast or an old lady - youll find the odd sunken treasure, but also a lot of monsters. Many people buy a 16v, realise they need to be loved and then sell them on with problems.
I bought what looked like a really nice example, with engine mods and leather. Despite a new engine, clutch, brakes and sound bodywork, Ive spent the best part of my spare time and money over the past two years replacing practically everything on this car.
But they look beautiful (especially with no exterior mods), make possibly the best 4-cylinder production engine induction roar and are damn fast. Oh - and theyre only Group 12 insurance too.
Prices amongst enthusiasts depend on condition - not age or mileage (though an extremely low mileage/young example will make extra).
The leather is well worth it, as I know - but it will add about £500 to the price. Phase2 is the spec to go for if you can: its build as much as looks. Ive got an early Phase2 (on a very late L-reg) and the doors shut with much more of a good thud than my flatmates Phase1; meanwhile, Ivegota16vs late N-reg doors close with more of a good thud than mine! (not that doors = total build of the car of course!).
The world of buying a 16v is full of perils and gems. The pricing is totally unfathomable. Throw your price guide in the bin and buy on condition. Youll see the odd 16v at £1500, but you wont be getting a premium example for that, mark my words! On the other hand, there are some real sh*tters for £4k.
I would avoid cars with big wheels (owners ask more and theyre hard on suspension/bearings) and wouldnt worry too much about high miles if the bils are there. There will be loads of cars with 60-70k miles on the market for good reason: its a very expensive mileage. If you pick up a car for a good price with 100k miles plus, it will probably give you less big bills (already done), but more annoying little jobs.
Overall, Im of the opinion that 16v owners are of the demographic that look after their cars well - enthusiasts. However, the cars are fairly maintenace-intensive, so, as ever, the care it has received thus far will usually dictate condition. Look for a big folder of bills.
What you should then be looking for then can be split into categories:
Exterior:
- Rear arch lips are susceptible to rusting, front ones are plastic so arent a problem. Rust also possible on door bottoms, around window rear quarters and boot bottom. Rear arches are now only available as an entire quarter panel - £330 from Renault inc VAT each side - so make for an expensive repair. Other body panels are surprisingly reasonable after a recent price cut.
- Front fogs (expensive) are prone to cracking due to stone chips.
- Bonnet and front bumper also prone to stone chips.
Mechanical:
N.B. due to engine size, many otherwise simple jobs on 16v/Willy are engine-out jobs.
- Cambelts must have been done before 72k (many advise a cambelt change far earlier); fairly big bill in itself and mega bill if it snaps in service.
- Diffs, gbox and clutch are all expensive jobs so check carefully. Jump off the accelerator in 2nd to see if it pops out of gear: if so, then suspect the box or the "dog bone" engine-to-subframe engine mount.
- Rear brake callipers can seize. New rear discs also necessitates new wheel bearings.
- Check aftermarket exhaust mountings - often a poor fit; rumbling under load can be caused by poor exhaust manifold to downpipe gasket (cheap job, disturbing noise).
- Erratic idle commonly due to faulty throttle potentionometer or idle speed control valve (respectively a specialist job and a straight swap).
- 16v/Willy run hot, so check coolant system - hoses, rad, expansion tank, water pump, anti-percolation (if you can). Radweld works wonders with minor radiator leaks.
- Engine mounts often go - embarassing and expensive to have your engine fall out, so see if engine rocks back and forth by opening bonnet and pulling accelerator cable.
- If car has induction kit check security of air hoses - can explain erratic idle or apparent air leak.
- Steering racks and columns are common failures. The handling reaction will be a second or two behind steering input in such a case; car will also tramline and follow road too much.
- Check for snapped front springs.
- CV gaiters should be checked - manifested by clicking noise on full lock.
- Handbrake is normally not good.
- If lowered, will need new front strut top mounts sooner or later. If majorly lowered, check to see that brake pressure-regulating control valve has been adjusted at the rear - otherwise the back wheels will lock too easily. Lowering also places extra strain on front anti-roll bar mountings and bushes and the track rod ends.
http://images.cardomain.com/member_img_b/286000-286999/286766_22_full.jpg
Interior:
- Sunroofs leak - tough luck!
- Electric window and mirror switches are very expensive - so check them too.
- Front seat belt reels often become ineffective - especially the drivers one.
- Door handle rods in door mechanism can come loose, so that the handle wont work. A time-consuming but easy job.
http://images.cardomain.com/member_img_b/286000-286999/286766_15_full.jpg
thanks a lot ben, that has really helped, will print that off now :cool: much appreciated.
anyone got any opinions on what i should be looking to pay for this car?
Ad
Hi adam,
Glad you decided to show your face, i told you these people was a friendly crowd, tho some of the peeps are alittle crazy ;). I think Ben Hs buying guide just about covers most things. I noticed you live in bromley? i work in Sidcup / Kent. You are more then welcome to come have a look mine, take you for spin even. Think you own a RT at the moment? The 16v (valvers as we call um) in comparison will blow your socks off. The chassis design and pulling power above 4,000 revs will have you looking like this for a week! -------> :D
The asking price is a far price for its age / miles. Tho these cars do need to be looked after, having lack of service history is worry. The cambelt change is going to set you back around £200 - £250, id advise taking it here for that http://www.bbperformancetuning.co.uk/http://www.bbperformancetuning.co.uk/ (p.s its "not" an engine out job like the peeps on the over forum suggested!)
could go on all day about these cars,
bottom line is..... if you buy it, make sure you join cliosport.net its well worth the fiver.
James.
  Was a Clio 1.8 16v
Adam, there worth around 4k for a good un. Do ur homework but i will advise that u hav to love a 16v to keep it to A1 condition cause the running repairs r higher than the entry level Clios even for a minter.
A generally BIG fun car which will rinse a lot of other hot hatches. If u like hatches & sprited driving then there is nothing better for the money IMO.
Mikey.
god i hate it when Ben H puts that reply up....takes me three weeks to scroll down it !!...lol
Anyway......hello adam.......if the valvers in nice condition then try not to pay more than the galsses guide price.....you should get a bargian then !!
thing is.......the people on here know what their car can fetch & the people that dont know much about clios just see them as another secondhand car.........so all being well you should get it for a song mate...........i cant really value the car unless id was looking at it.......but to give you some idea.......... i paid £1900 for mine (sept 2002) with full Renualt service history, leather & ABS with 69k on the clock , in monaco blue....it had a bit of rust round the rear arches (common on clios) but the cam belt had been changed @ 65K ....everything on the car was standard & it had not been modded in anyway !!..........the guy i bought it from loved it to bits & was a bit upset to sell it....(he paid over £9000 for it in 1995 from a renualt dealer) ..........even more so...seeing as he originally wanted £2500..........£600 off was poor for me..i usually beat em down a bit more !!...but the car had been well looked after & you could tell it had never even been thrashed !!.............Id say if it was a nice one....try to pay around £2500-£3000..........then youll know youve got a bloddy bargian !!!............its a buyers market at the moment for most cars older than 5 years !
hope this helps.......
& dont forget..........if you buy it join Cliosport....youll save more than the £5 membership when you need parts for it !!
thanks for all the advice guys, :D
thanks james, i may have to take you up on that offer some day!
the owner at the mo is not an entusiast but does know a little bit about cars, the parkers guide rates it at £2100, so im going to use that against him as a bargaining tool, esp as the cambelt hasnt been changed. im not too fused about the cambelt being changed because i have some safety money saved up for the car, just incase anything major goes wrong.
i cant wait til friday to find out the condition of the car!
Ad
nice 1 adam, keep us updated.
like i said if you wunna come check out my valver its not an issue, anyway i wunna pic your brians about a box design for my new 10W3v2 , how well do you know this EGMAX box designer Adam?
EFMAX is the daddy of all box designers, i got a box design done when i had my kicker solobaric, it was amazing, the best £20 i spent on my ICE back then!
i highly recommend his box designs, nice sub you have there, if you have the time and money build the recommended sealed box from http://www.jlaudio.comwww.jlaudio.com and then get yourself a design from EFMAX, usually ported designs, build that then decide which one you like most.
HTH
Adam
