Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Ive seen a clio 172 in the gallery with silver door handels. Where are these from? Ive heard that you can get silver metal ones from the Renault megane??
I had a Megane as a hire car the other day and actually took one out to see if it would fit. It fitted fine but the plastic surround was black so didnt match the rest of the blueish plastic in the car. If I had time I could have swapped the actual handles around but was a bit rushed.
Warren Chaplin (smileysport) here - its my car you saw in the gallery. Its a very quick easy job, but as towser mentioned, the plastic surround is black instead of blue, so when you get the part, unclip the spring at the back, remove the silver part and clip it into your existing blue surround.
I just wanted to refresh this, as im still after those silver door handels. So, please can someone inform me of the part numbers so i can order direct from renault. Many thanks. James.
When you undo the screw and pull them away from the door you will see a steel cable with a small metal pin that fits into a slot in the handle. You just pop it out. Simple as that.
