Right, when i first got the car the cat to centre pipe connection had a leak at the clamp which was then fixed.
Then the cat to manifold connection went so was leaking again and has now been replaced with new fitting kit.
But I just can't decide if there is still a leak somewhere or not, it sounds to me as if there is. But I can't see anything. I also have no centre silencer so the exhaust is slightly louder anyway.
How can I check for sure? I'm a bit of a perfectonist when it comes to stuff like this.
EDIT: Also could it be there is a slight leak when cold but as it heats up it slightly expands and seals the gap?
