HU turns itself off
hey
just fitted my sony HU and every time the key is taken out, the HU has resetted itself when the key is put back in! its very annoying cos all the settins go!!!!!!
what cud be da prob
Sounds like the permenant feed and the switched feed is wired the wrong way around, so every time you switch the ignition off its like disconnecting the battery.
Just a thought tho
  Mr2 Roadster
Yep, its defo the power and the ignition feeds... Need to switch them round. Used to be red and yellow wires...
Hope that helps!
  350z & 16v Maxi
Gilly just swap the Red and Yellow wires in the loom that came with Sony over. You should have bullet connectors on those wires.
That is deffo the problem
Just a thought tho
Yep I reckon so too!!!!!!! :D
