how do you do a screen print of a full window?
Ali
  V6, Trackhawk, GTS
I'm not an I.T guru as you know.
There stuff out of scroll vision which i want in. Must be the full window.
Thanks - Ali
seb
  Clio trophy
This should help you too.
CTRL + Print screen
Why Ctrl? PrtScn by itself screen prints, Alt + PrtScn for active window. Should then be in the clipboard for pasting.
Just reread what you were looking for, don't think you can copy stuff out of view.
Tom
  EV (s)
Why not?, alt + print screen just does the window you are working on, but if you need to capture anything with scroll bars you are screwed AFAIK
I just read the title.
Work it out yourself you rude caaant.
Ali
  V6, Trackhawk, GTS
Not a case of being rude! You just didn't read it properly!
Ali
  V6, Trackhawk, GTS
ALT doesn't work either. Cuts of the tool bar which is fine, but doesn't get the whole window in.
Never mind.
DrR
  VW Golf GTD
It's "print screen" lol
then just paste it somewhere like paint.
  Barge
I think the issue here is Ali wants a whole document screen printed... So what lies further down the page, e.g. when you scroll down. Not just what he can see on his immediate screen.
TBH, I'm not sure you can do that. I'd probably have a think about what it is you want to print... Can the document be turned into another format, like an image?
Ali
  V6, Trackhawk, GTS
imagine you're window open (Computer screen for clarity) and you can't see the whole page! If i Print Screen it will only capture whats in view...All clear?
Tom
  EV (s)
There's something in vista called a screen sniping tool, try that?
(Probably using XP tbh)
Told you you didn't word it properly.
Ali
  V6, Trackhawk, GTS
I think the issue here is you want a whole document screen printed... So what lies further down the page, e.g. when you scroll down. Not just what he can see on your immediate screen.
Claps! Exactly...It may well not be possible! just asking! if it's not then tough i'll go without.
  Barge
I have that on Windows 7 too, Tom. It's a bit like a screen print, but you can save it as a jpeg, etc.
I'll try a custom snip and see if it makes a difference...
EDIT: Nope... doesn't work. It just snips the screen you can see. Is it a word doc, Ali?
Tom
  EV (s)
The only other (easy) way is to bang up the screen res and then print the screen.
Ali
  V6, Trackhawk, GTS
Correct. Professional. Don't know if that makes a diff...Doubt it.
Ali
  V6, Trackhawk, GTS
Nah. It's an ARAMARK system tool. Web based.
Tom
  EV (s)
As in it runs in IE?
Ctrl + A, Copy and then paste it into paint/word?
  Barge
Hmmm. And you can't do two screen dumps just for ease? I'd screen dump one half, paste it into paint, screen dump the other half paste that into paint and merge them together as discreetly as you can. Save as a jpeg > print.
  Cupra
I use a screen shot app called Hypersnap. It can automatically capture a full window. There are probably some free apps which can do it too.
