Holy Cow how much are spark plugs!
-J-
  RS2'ed 172 Cup
After my running problems with my car I Just popped into Renault Watford to price up a set of NGK's for my 172, i had seen them on Ebay for about £7.50 each but was warned off them by my old Man (Senior BMW Tech for a franchise) who said that they had seen alot of cars with running issues due to counterfit plugs.
Thought probably about £10 - £12 each from Renault, Nearly fell over when they quoted £18.75 + VAT Each (£22.03 each) so £88.12 for a set :S
So rather than buying them i have booked in for diagnosis £50.34 for Clip faults to be cleared, Test drive and Re-Check faults so at least I should know what needs doing rather than blanket Bombing the issue repalcing parts that are not needed!
I Guess on the upside its cheaper than BMW's labour time of £195 Per Hour plus VAT !:lolup:
  C-VXR, T8 Map 220BHP
think you can get four NKG ones for about £25. forget which is ok for the rs though, but you can get them
  clio 172 cup
I have just purchased them ngk's off ebay, but not fitted yet. I hope what your dad said is not the case, can't be doing with having to buy another set. I think a few people on here have got them plugs off ebay and as far as I'm aware I've not heard of anyone having problems with them. Well fingers crossed anyway.
-J-
  RS2'ed 172 Cup
Im sure they are not all knock offs (Maybe none are) But I would rather be safe than sorry if you get what I mean ;)
-J-
  RS2'ed 172 Cup
TBH i have read so much about "other spark plugs" causing the car to run poorly I think ill stick with the NGK PFR6E-10.
Hopefully after diagnosis ill know if they need repalcing... May turn out to be something else.
K-tec though innit? Not gonna be dodgy or anythin..
Im Not saying anything K-Tec sell is Dodgy (In fact I rate the service the provide) But over on renaultsport and alot on here have all said only use the NGK PFR6E-10. It also states in the Handbook specifically not to use any plugs other than standard.
  123D Coupe + MK1 MX5
Oh right, hehe..
B
Bucko
My cars done 74k, i bet they've never been replaced. I had no idea until reading this that the plugs were so expensive and such long life.
I think i best give it a service, including plugs, pretty soon as it was due this month.
  Mk2 1.2 Campus
To be honest I doubt a clip will tell you what exactly is at fault, it will diagnose a misfire but that could be caused by the coil pack, leads or plugs
  m-tec bmw 325 ci spo
i went to halfords and bought a set of bosch super 4's listed for the 172 for the gfs 172 thats was mis-firing lob them in and its running sweet now mate and they only cost 20 pound
  Mk2 1.2 Campus
I tried these before and one of them lasted 150 miles before it gave up, think I may have had a dodgy one but it put me off so I went for NGK
realnumber 1
If its your 72k/5 year service thats due then you have more to worry about than your plugs.
Got mine due in a few months:(
B
Bucko
Bad luck mate, it's my 6 year service. The belts were done last year at 70k by the previous owner.
All i know is i will be using NGK, i was tempted by the Bosch super 4's but i'd be a fool to buy them after everything i've read on the forum about skimping on plugs.
  172 FF
I had some of them on an xr3i ages ago & one of them fell to bits after a couple of months. The whole inside of the sparkplug just came loose :/
Maybe they are better now, but I would personally stick to NGK, which I have used in all my cars ever since.
-J-
  RS2'ed 172 Cup
i realise it will only suggest an "Area" that could be causing the issue, But with a missfire as you rightly say it could be anything, But with an injector having shut down what im looking to find out is... Is it just a simple Plug/Lead fault (I Know its not the coil) or a fueling issue or something else.
  Mk2 1.2 Campus
I'd personally try a mates coil pack and/or leads first, then plugs and I'd be confident it'd sort the problem. If it's still there then look at injectors
i also had a mis-fire and it was caused by the ht leads touching my plenum making it ark out so check that to
