I'll try and remember everything...
ECU has been converted to 'free running' by ECU Clinic. I'm using the 172 engine loom, and ECU, in the R67 connector I've connected:
white 1 - starter +
white 2 - ign switch position 2 (12V)
white 3 - fuel pump
white 6 - ign switch position 1 (12V)
white 7 - gnd for starter relay
blue 1-6 - throttle pedal
black 2 - alt light
black 5 - oil pressure light
black 8 - CAN-
black 9 - CAN+
When I switch the ignition on I can hear/feel the fbw throttle singing.
The fuel pump/ignition relay doesn't energise - if I pull the ecu line down the pump runs.
I've checked for gnd on ecu pins 3,28,33,67
I've checked for 12V on ecu pin30
I've checked for switched 12v on ecu pins 29 and 66
I have an Ebay elm327 obd reader, and using EasyOBDii software, it connects, and says the "vehicle data bus OK", but says "no vehicle response / connection or power" however I can hear a relay clicking away as it tries to connect.
any idea what's missing? or what else I should check?
thanks
Andy
white 1 - starter +
white 3 - fuel pump
black 2 - alt light
black 8 - CAN-
black 9 - CAN+
thanks
Andy
