help needed
  renault clio 2005
Hello I have a 2005 clio 1.2 and it cut out the other night along with the stop light appearing and now it comes on accompanied by the battery light, if someone could give me any advice it would be greatly appreciated
Chrisgti6
  MR2,TT V6,Swift,Mini
Does the car start now or not?
I'd test the battery first, voltage isn't the perfect indicator - but it's better than nothing. After that I'd get it started (jump leads or bump it) and test the battery again, you should be seeing a higher voltage than when you tested the battery (if the alternator is working)
