help. lifted the cam cover
  Clio 172 cup
Hoping for some advice. I've a Clio 172 cup, had some issues with immobilizer. Reset and cleared codes but then it ran bad, struggle to get passed 2500/3000 revs, rough idle and emission engine light was on. Diagnostics said the lambda sensors but put this down to the decat. Mechanic friend said plugs/leads. Took the inlet off and thought I'd take the cam cover off to paint not realising its not like normal cars, only lifted one edge 10mm if that. Then decided to google why I wouldn't come off. Have I messed up? I bolted it back down swore alot. Plugs were fine btw. Really losing the will to live an love for this car. I know I should leave somethings to those who know. Any help would be appreciated. Thank you
Jekyll
You need to jack the engine up from the sump. Put some wood under a jack and raise it a tad then you'll be able to remove it.
Forget that, I thought I read cam belt cover.
  Clio 172 cup
In removing the cam cover, its not going to affect timing or the cam belt is it? I really don't know renault(vw lifer)
bashracing
Don't risk it,
Have the belts and dephaser done while it in bits and put it down to experience,
No need to paint the cam cover, not seen a rusty one yet.
  Clio 172 cup
Hopefully not just myself, belts an dephaser were done in April by previous owner but the rear of the cam cover leaked afterwards, I foolishly thought it would be an easy fix while I tarted up the bay. Will get someone in the know to carry out the rest of the work. Thank you everyone for not giving me stick
  Clio 172, Escort RST
We've all been there, well some of us have.
I once went for the head bolts on a VW PD engine instead of the cam bolts. How I felt like such a wally!
MJClio
South East - Kent
  Ph1 Clio 172
Very nearly did this myself, was only when I went to order a gasket and couldn't find one that I asked my mate who has one and he told me not to lol
Happens to the best of us pal
  Focus RS + S3
Quick question, whats the reason they cant be taken off on an F4R?
Like what part does the cover play?
Really curious
