Evening. does anybody know what thickness head gasket i will need to retain my 8.5:1 comp ratio. i know standard f4r is 0.65mm and the meg is 1.30mm. but need it to be neutral and not affect comp ratio
Depends also on if the block has been decked or head skimmed as those will raise CR, Also if the chamber has been worked it will lower the CR, measuring is the only way to know. The quoted figures are nominal only.
