HDMI PC to TV
  330Ci M Sport
HDMI output from a vaio laptop to HDMI interface on a 32" HD TV = what i see on laptop is what i see on tv? ie....will i be able to use the tv to show exactly what my laptop screen displays? cheers guys.
  Fiesta ST
you should beable to two things:
1. Mirror your display
2. Extend your display - use boths screens as one monitor.
  UR R26R.5, VW Golf R
In a word yes. It displays everything thats on your laptop screen in a much bigger world :)
Bear in mind you'll need to set your sound up, as the only sound output will be from the laptop still.
  Rav4
my mac looks s**t on the TV. Misses 10 pixels on the top and 10 on the bottom, quality of pic, in terms of colour and how its represented does not look good :(
  BMW e46 320 Ci Sport
weird, didn't think hdmi was on laptops yet, that laptop must have cost a bomb! prob still better off running it through vga anyway...
  Revels Mum & Sister
Can you not install a program (Name Escapes me) to run custom Res, i.e the Weird ones some Plasmas and LCD's run and match it 1:1
or dont that work?
KDF
  Audi TT Stronic
I dont see why it wouldnt.. a 1:1 match is always going to look best.
Edit: Powerstrip 3
most lcd's atleast wont pixel map especially 1366x768 res screens some do 1360x760 and weird stuff like that some wont even do anything above 1024x768 !
and this can all change depending on the input that is used best way is to see on avforum if someone else has had a 1-1 map on the input and screen you want to use
the one im sending back does 1-1 on dvi hdmi and vga but overscans about 5% on component
  A4 Avant
I recently hooked my laptop up to my 42" plasma using vga at 1024 x 768. I'm impressed by the results! There was minimal overscan and everything was readable. Far cry looked great!
KDF
  Audi TT Stronic
^^ Same here.. I use the VGA port for both ma PC and ma 360.. looks so good !
its only really a problem when half your start putton and your clock vanishes off the side of the screen with overscan
