Gearbox gone!
  Clio 182 FF
After what I thought was a tie rod/ball joint related problem, turns out they were fine! Went on to find out it's something much worse. Been diagnosed as busted diff bearings. Problem I've got now is, do I buy a second hand box or do I just get a rebuild? Any suggestions for builders and breakers around South Wales or south west would be greatly appreciated
  monaco 172
Sure it's not the joint on the end of the driveshaft thats gone making it look like the diff bearing has gone?
  Clio 182 FF
Could be, any help is appreciated really
Best way to describe it is that it feels like wheel balancing but a lot more violent. Only starts come on about 40 plus, starts off pretty gentle but at 75-80 it's really violent. It doesn't do it all the time either, It's there more often than not though. Last guy who looked at it said the box has run dry, over heated and warped the bearings, made sense to me if I'm honest.
  monaco 172
I'd take the drive shafts off first and check the roller bearings on the end and cv joint and also the wheel bearings.
Drain the oil first so you can see of his theory is correct, I'm a bit sceptical to be honest.
  Clio 182 FF
Sounds more like the drive shaft to me.
Hopefully is a driveshaft to be honest. The box had been run dry for about a week because of some incompetent idiot mechanic! Won't be going back there again! Going to see a gearbox specialist today and see if he can give me a proper diagnosis on it.
  monaco 172
How did that happen? I'd be trying to claim from the garage whoever forgot to put oil back in
  Clio 182 FF
He popped the n/s driveshaft out somehow, put it back in but not tight enough, re filled with oil and it all come back out! Tricky situation because he's a mate, I'm just learning my lesson and staying away from there from now on
  Clio 182 FF
Yeah it was, was only for about 5-6 days before I realised it wasn't right! This is the thing it could be proper farked and might just be easier to get a second hand one, seen a few around from breakers. One company wanted £800 for a rebuild and fitting
JamesBryan
Considering it's about £200 in labour to fit, £600 isn't bad for a rebuild depending what it needed.
Cheaper to get a 2nd hand one though like you say.
  Clio 182 FF
I've just been up to a gearbox specialist this morning, said it's not gearbox related but driveshaft related instead, kinda glad about that
  Clio 182 FF
That sounds like the symptoms I had when the n/s shaft roller bearings came off and flew around the gearbox. Resulted in a gearbox rebuild unfortunately.
Luckily the rollers were intact. Guy this morning seems to think it's o/s driveshaft spring that's gone, needs it up on the ramp to check though
