Front end camber
olly-r
  clio
I race a 05 182 but its not a cup chassis, i want more front end camber, cup arms any wider track? or shall i just elongate my lower arm ball joints?
Any other racers here?
  mk1 Octavia VRS
How much camber do you have now and why do you want more?
You can get camber bolts if you don't have them already. Some shocks also have elongated holes to allow camber adjustment.
mad in general
  Clio 172 phase 2
Just with you mentioning the cup chassis
Do you mean camber or caster?
Camber = adjustable bolts, around £25
Caster = cup chassis wishbones £60 each I think
Edited to add
I may be picking you up wrong
olly-r
  clio
Yeah i know fella but really want to kick the bottom of the wheel out to get a touch wider track as will help with stability , what's the differance between cup arms and non cup?
mad in general
  Clio 172 phase 2
Only difference is cup arms have extra caster, it sits the wheel further forward in the arch.
I don't have any idea about a wide track conversions
green
  Hi comp phase 1
@NorthloopCup's roll centre hubs give about 5mm extra track which in turn could give you more camber. That's my thinking..I'm sure some one with more knowledge will confirm this. How much camber are you looking for ?
