Ph1 T
Right ill start from the begining but try and keep it short. Pass wheel fell off while driving round a bend around 15mph cause not sure maybe me not tightening bolts fully maybe not anyway bought a ph1 driveshaft and hub as the bolts snapped in hub and shaft was knackered before.
Fitted the shaft and hub today shaft went in fine bolted to gearbox, fitted hub on now heres where i was struggling i couldnt/cant get the 2 bolts what fix the hub to the wishbone to sit perfect well the one closest to the hub just wont seat right but it tightens up solid the other one sits fine.
The only thing i can think of is maybe ive bent the wishbone when the wheels come off? i cant see why the hub bracket should not sit perfect on the wishbone..
anyway needed to get it home from work and as everything was all tight its pretty safe to use, heres what ive noticed since everything back together:
Car pulling to left an awful lot (expected maybe just tracking).
When i brake sharp the front end kind of swings right then left, also brakes feel spongy compared to before where was really sharp.
Loads of camber but so does the drivers side.
When car was on stands i started it there was a tapping noise when the wheel was spinning can only hear it when put your head up next to the wheel everything sounds fine from inside ect no more knocking so the drivehsaft is fine..
I just couldnt understand the hub to wishbone been so difficult to line up when it was fine on previous
Any help or opinions much appreciated
Thanks Dan
Thanks Dan
