F7* Big End Bearings
A
ashy_gtt
Does anyone have a part number for big end bearing for an F7P/F7R engine?
I'm after a tagged set and the F4R bearings I've used in the past are plain as below.
Thanks Ashy.
Jaff.
Renault only supply f4 bearings now they don't supply the tagged f7 anymore as the f4 are used
  R5 gtt, R27 F1 team
Seems a bit expensive, this is the part nr for acl's: AB 4B7820H 000 Cost €80 in NL so must be gotten cheaper....Federal mogul suplies tagged bearings however i don't know the part nr as i binned te boxes...
  R5 gtt, R27 F1 team
well if i had heard it right his spun a bearing so hence choosing bearings incl tab now ;)
  DON'T SEND ME PM'S!!
only reason it will do that is a failing oil pump, or incorrectly torqued rod bolts. I would go with the oil pump option myself.
If there's enough journal contact to spin a bearing, a tab isn't going to make the slightest bit of difference. Also once a rod has had a bearing spin, it's usually scrap
  Trophy Turbo :)
I agree with Dan, some thing internally has caused a bearing to spinn, and even with a tagged bearing would have also happened, look at Subarus there tagged and spin bearing for fun!
Im use it wont be a Mechanic error from Ashy hes a top engineer. i think it may be the fact his is stupid BHP ;) Ashy hope your using top oil and not soem stuff from Pages LOL
  182/RS2/ Turbo/Mk1
Tabs make no difference, it might spin 2 milliseconds later or something, but it will still spin.
A
ashy_gtt
Yes it was a partialy blocked strainer on the oil pump. I will be checking the rod once its out to see if its useable.
Thanks for the help chaps.
A
ashy_gtt
There has been a slight color change in the rod that spun the shell. However, as forged Rods are manufactured from 4340 Steel and the anealing temperature of that grade it around 800 degC there shouldn't be a problem with the rod reaching 200 - 300degC (gauged from the colour change). As has been said though the rod will be fully inspected and compared to the previous measurements taken to ensure the size and shape is still good.
  182/RS2/ Turbo/Mk1
Is there scoring on the rod from the bearing spinning? If so I would be binning it personally.
If its a quality make like an arrow it will be easy to get a single replacement but if its one of these generic Chinese ones like pec/ed etc sell be careful as the batches vary a lot from what I have seen.
