Exhaust Emissions warning ligt? Power loss?
The Chubby Pirate
  Golf R
Theres a hole in the exhaust just beyond the back box, i can see exhaust gas expelling from the hole.
Does anyone know if this could cause a loss in power as the car seems to be struggling to go smoothly (i.e its stuttering along)
Will a seem weld fix the problem temporarily whilst i get some funds together to get a brand new exhaust???
Help:dead:
  172 FF
Yes a hole in the exhaust can cause some small power loss or running probs . A weld or patch should solve the problem.
My exhaust cracked around the join on the back box & fell off. I got it welded back on & it has been going fine since. That was well over a year ago.
  b/g 182, meg tourer
my brothers had a hole in it in the same place. fix it with a weld/patch or replace it before it falls off... his did
The Chubby Pirate
  Golf R
Right ive taken it to a local exhaust specialist and it turns out that it isnt the exhaust atall causing the problem, turns out the car is firing on 3 cylinders, it could possibly be Spark plugs, HT leads or a coil pack.
Not good whatever it is!
C
clvs2222
easiest thing to do is test them. loosen all the cylinders and then pull each one out to so which one it is. if it doesnt change then change your spark plugs before the ht leads as its more likly them.
