Engine mount help...
  E36 328i
Hi gents,
I've done a search and can't seem to find the info I need.
Basically I'm looking to refresh all of the engine mountings on my 172 cup as there is a lot of engine movement and feels quite jerky in traffic. I have a dog bone mount already, but I am not sure how many others there are. My understanding is that I need the following:
http://renaultpartsdirect.co.uk/products/Renault-Clio-172-Engine-Mount-(O{47}S).html
http://renaultpartsdirect.co.uk/products/Renault-Clio-172-Engine-Mount-N{47}S.html
http://renaultpartsdirect.co.uk/products/Renault-Clio-172-Engine-Mount.html
Is this correct? Not sure if that's too many/not enough.
  E36 328i
Thanks mate, already got a poweflex one for the dogbone.
Where would that be? I'd ideally like receipts so I can add them to the masses of history it already has.
  182
Ring Adam on 01902 439264
Works at the renault parts supply base and will be the cheapest you will find..
  LY Megane R26
When you say the lower gearbox mount, is it the one that the gearbox sits on you want?
If so I got this one through Andrew page, it came in a Febi box but had the Renault part number on it. May be able to find the part number if you want?
They also do the other 2 mounts. If you get the O/E part numbers they will be able to cross them over, febi also do the upper gearbox mount and think it was Corteco that do the R/H engine mount, can't remember the exact costs was a little while ago to be honest.
