Droning from rear
  Ph2 Clio 172
I'm fairly certain one or both of my rear bearings are gone, as I have a constant drone coming from the rear that changes pitch with speed. But I've just jacked it up and there's no movement in the wheels. Is there anything else I should look for before ordering some OEM disks with bearings pressed in?
MarcB
  Too Many
I would say that its almost 100% the wheel bearings unless you have an issues with tyres not at the correct pressure.
Speak to @g172 about brakes if you need them as he supplies OE stuff at good prices and very fast delivery
  Ph2 Clio 172
There aren't any spacers, checked when I changed pads last time and the previous garage that changed the disks obviously threw them out.
I've got new spacers and hub nuts ready, as I was always going to change the disks anyway. Its just the new droning noise without any wheel movement makes me wonder what else I should check while I'm at it :).
  SQ5
If there are no spacers it will be that. 100%.
There isn't much back there to drone.
If you checked for them and they weren't there, why didn't you get some?
