diesel engine flush, using diesel fuel
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
has anyone done or know of this method?
basicly from what i have heard, you warm the engine upto normal operating temps, then drain the current oil from engine.
then refill with diesel fuel atleast 1/2 - 1L more than the oil limit. run again for X amount of time, drain, repeat once more.
after the 'engine flush ' change oil filter and put fresh new oil in, (recomended or better )
i have a freind that has a 1.5 dci kangoo van with noisey valves (tappets/solid lifters/buckets/hydralic lifters ) which ever the k9k engine has...
will this method of flushing help clear the said valve train components to reduce noise if they are blocked?
or will this f**k the engine up ?
info much appreciated thanks
raz
  Golf GTD Mk7
Completely misread :) although if you run Diesel engines on biofuel it does clean the internals a little :)
  MK1DTi/vivaro/corsa
oh i get you now :), nope neither of us run biofuel. just plain old pump fuel with diesel injector aditive once every or so tanks
