Clutch & Accelerator Cables!
  Was a Clio 1.8 16v
My clutch pedal seems to lose tension with the clutch pretty often now. I think the cable is getting caught or the spring is useless and not adjusting properly. I sometimes put my foot down & it is slack untill right at the bottom where it will work, then itll pop back and have tension again, or work as usuall. Any1 know what this is? ITS NOT A WORN CLUTCH!
Accelerator pedal has always been notchy, will new cable fix it?
Cheers.
  Revels Mum & Sister
Wasnt there a problem with the 16V pedals. The early ones. I may be thinking of another clio. But it makes the cable and bits wear quicker. You can get a whole new assembly for £100
  Was a Clio 1.8 16v
I paid £21 from Reno for the pedal assembly.
Whats fitting a new accelarator cable like?
Mines very notchy so im gonna have a go at the weekend. Thanks
