Clio Mk3 Dynamique 2008 3dr, water/fluid in boot
  Clio MK3 Extreme
Hi all,
I recently purchaced a 2008 Clio Mk3 3dr as my first car and have encountered a couple of problems (many of which are now resolved).
Recently, I noticed that the appears to be a liquid stagnating in the boot. When taking the bottom carpet out to dry drops of green/dark blue fluid are dripping out.
I have removed the plastic trim on the car near the boot latch and stripped out the carpet type walls. It appears to be stagnating on the passanger side of the boot.
I have done a bit of research and it doesn't appear to be the boot stop or the brake lights. I believe it could potentially be the washer fluid pipe having a leak.
I wonder if anyone has had this problem and if so the fix they went with (any images/resources would be appreciated).
Thanks,
Luke
