Clio cutting out and rough idle
  Clio RB182 turbo
Evening all, So had the clio a few months and every now and then it starts to run rough and then cuts out. Anyway took it out at the weekend and every time I stopped it cut out and when starting back wouldn't run unless I revved it. Any suggestions on what it could be, I check the throttle body and the plugs and leads were new last year.
When driving it does old back now and again as well, then gives full boost (Turbod Clio) Weird one! Help? ahahha Cheers
1420885
  182 clio
Evening all, So had the clio a few months and every now and then it starts to run rough and then cuts out. Anyway took it out at the weekend and every time I stopped it cut out and when starting back wouldn't run unless I revved it. Any suggestions on what it could be, I check the throttle body and the plugs and leads were new last year. Help? ahahha Cheers
Any fault codes?
  Clio RB182 turbo
Had a 02 sensor Bank 1 code. Cleared the code and its still happening. Fault hasn't come back yet!
