clio 197 lambda sensor
  clio 197
Hi to everybody i'm Neil and new to the forum.
I have a 2006 clio 197 that started running a little rough & the cel came on, so i scanned for fault codes and it came up with p0135 lambda heater circuit, so i replaced the sensor cleared the codes and everything was fine for 2 days. Yesterday there was no power when cold and the cel has come up again and the same code showing, is it pointing to the wiring or something else as its only a generic fault code?
the car runs ok when hot slight popping from exhaust and a very slightly lumpy idle.
Cheers for any advice
Neil
  172, Tiguan
Hi Neil. It might be injector related, but your best bet is to run it up to a specialist that knows what they are talking about.
