Hi guys,
I have odd problem with power in my Clio 172... Sometimes car pulls hard, sometimes like 40 hp less.
What i did:
Full OEM Timing with dephaser
OEM NGK Spark plugs + oem Beru leads
replace coil
All new fuel injectors
Oem carbon canister + oem thermostat
New air filter + clean throttle body
New Delphi pre cat oxygen sensor
run always on 98 or vpower
compression check
Other symphtoms i observed:
Rough idle + popping noise from exhaust
Floor in catalist place is hot (sometimes in hot weather I can not touch for a long time rail seats)
sometimes won't start at first try
any suggestions?
Cheers!
What i did:
replace coil
compression check
any suggestions?
Cheers!
