Clio 1.2 16 v ABS and SERV light 2005
  clio 1.2 16v
Need a bit of help. A while ago the ABS and SERV light appeared on the dash in my clio 1.2. MOT 's coming up so it needs fixing.
Ive changed the abs rings as one was broken. Cleaned the sensor and other wiring. The light is still on? Any other ideas on what it could be? Tried disconnecting the battery but didnt help
Any help would be appreciated, thanks.
  Clio 1.2 16v Dynamique
Checked all 4 sensors? Any cuts or marks on the end of the sensors??
I had the same issue on mine. Diagnostic showed a mechanical fault at the front o/s abs sensor so naturally took a look at the ring. Ring was fine but for the sake of a few quid I changed it anyway. Thought I'd just check and clean the sensor too whilst I was at it and found the end sensor had been chewed up lol changed that £15 from ECP and hey presto!!
