I have a renault clio dynamique 54 reg
I had a sub and amp connected to my headunit, today while the car was started and the cd player on, the live wire (the red one that goes from the amp to the car battery) came loose and touched something i guess another wire and made a spark and the cd player just went off and so did the clock that appears on the dashboard.
First i though it might be the fuse on the amp so i changed it but no luck, i have taken the live wire off from the battery and the amp, but my dashboard clock still does not work and also evrytime i put the ignition on the car makes a noise from the bonnet i dont knoiw where it is coming from the sort of noise a car makes when you leave your headlights on whenthe car is switched off and open the door.
what have i done and how do i sort it out??
Any Help would be much appreciated
