Clio 172 cup
Hi all I'm having trouble to get the camber correct on my 172 I took it to a good mate of mine at kwik fit as they have the Beas knees tracking and camber machine,now the passenger side front was at fault it had to much positive camber the drivers side was ok ish,so he adjusted it best he could its a lot better but still not in tolerance I'm running k tec coil overs can you get the camber adjusting bolts for them if so will they cure my problem what's the difference with these and standard bolts cheers mart
