brake check
  172
today i drove into a garage to get my brakes checked as they were making a bit of a clicky noise every so often..... after about £15 minutes the mechanic came out and said maam your car is very dangerous... both discs were cracked one of the calipers was jammed.......etc etc
in the end he gave me a quote for £860, to get it all fixed.... i could have cried. i am going to try source cheaper parts from somewhere because there is just no way i can afford that..... its 3months wages for me!!! (full time student and only work 11hours a week)
ideas...?
  Bus w**ker
Having you on. Walk away and see someone who isn't a robbing c**t and that has a clue. Then go back and run over the guy that quoted you.
a good independent garage should easily be able to source and fit new front discs/pads, and free the caliper off for less than £200 i'd have thought (depends what's up with the caliper)
DrR
  VW Golf GTD
Can get a set of front pads and discs for £75 posted on ebay.
Peice of cake to fit.
LOL at 860
as DrRollos comment ....EBAY for pads and discs as for calipers have a look on ebay again loads of cars being split for parts or try ppl like clio spares ect
fitting them yourself will save you a lot of wedge to it really is an easy job about 2 hours work
sure there will be a guide on here somwhere if not can talk you through it
would save your self at least 600 sheets
Da
  Less
Yikes! :eek:
As stated though, all that can be rectified for £200~ if it even needs doing at all!
  ITB BG 182
Hayley, was it a stealership you went to?
I had a problem like this ages ago, went to dealership and they told me i needed new brakes plus an exhaust, quote for £1800 just for parts, got it all done at the gods of GDi and Milltek for less than £500, £1300+ saving
  In between cars....
Just noticed your in Edinburgh, sure a couple local folk could change disks and pads for you if thats all you need
  172 cup
or i could sell you my standard drilled and groved discs with a set of ebc green pads and a pair of standard 172 calipers too due to i have four pot hi specs there just sitting around collecting dust now :)
Matty
  "Navy" N17 TWO
I went to a wheel specialist last year to get a price on rear discs & pads for MOT and they argued with me that no Clio's had discs/calipers on the rear.
I was like "follow me".....pointed...laughed and still got a really good price! :p
  Golf GTD Mk7
lol thats such a piss take. How are they justifying that price? If the calipers are just siezed they might need a new seal kit and a clean. As said, disc/pads easy to fit. Lots of guides in the guide section. Think they have seen a girl (no offence :)) and thought "kerching"!!
  "Navy" N17 TWO
Hayley you could print this out and bring it in to them, see if you get any discount :rasp:
