172 cup
right....
i can move the arm that the hand brake cable attaches to, i can move it fully backwards and forwards. when i do this, i can't see anything else move, what should be happening when this arm is pulled round by the hand brake cable? i see the piston sits on the threaded spline, when you press the foot brake, brake fluid is pumped in to the caliper and pushes the piston out, i presume it goes out in a twisting motion?
I've put the calipers on, bled the brakes, pumped the brake pedal so the piston is fully out, then i've attached the hand brake cable and adjusted it up fully, the hand brake pulls up a couple of notches (as it should, it feels like it should be on) but the hand brake has done nothing and is not holding the car
when i move the hand brake cable lever, the little rectangular plate it presses against, doesn't move? is this right? what should happen when you move the hand brake cable lever? how should this put the hand brake on?
