it doesn't matter, but you may as well do it afterwards (may need to draw some fluid from the reservoir if you're also fitting new pads and your olds were noticeably worn)
Is it worth investing in an Eezi-Bleed system? Not sure I could get the wife's help for the time this malarkey takes! (short attention span when it comes to cars!) I've found one for £13 delivered on eBay...
Eezi-Bleed is very handy. As long as you get a good seal on the reservoir and you make sure there is not too much pressure in the tyre you hook up to it.
This was the only order that worked for me after sucking air in, so I would personally recommend this. Oh and definitely after, unless you want your reservoir to overflow when you fit the new pads & discs.
