best way 2 bed pads in?
Paddy_g46
is this the best way 2 bed pads in?
30-5 3 times, 60-10 3 times 80-10 3 times? just do that yeh?
oh and iv got new disk on aswell, does that matter?
  Fiesta ST
^ I made that mistake. You see new discs need to be used gently otherwise you can warp them. HOWEVER, new pads need to be done like you said, by doing a few 30 - 0 stops and then 60 - 30 stops. Or a combination.
So that's what I did, and when I pulled back in my drive the discs were smoking (obviously I had taken the surface off them) but luckily they aren't damaged. Phew!
So perhaps the best bet is to take it easy for say 50 - 100 miles and then do the harsh braking to bed the pads in properly?!
Each pad has different bedding in I've always bedding mine in with some hard 60-10 stops or a lot of left foot braking and never had any trouble.
You have to get some heat into them early to get rid of the protection on them.
MRBILLYUK
  FF Jeden Osiem Dwa
Like edde says , left foot on the brake as you drive helps to bed em in faster .
Paddy_g46
good job i know how 2 left foot brake! otherwise i wud have gone out and crashed! if u tell ppl to left foot brake make sure they know what 2 expect!;) but cheers for the tip!
MRBILLYUK
  FF Jeden Osiem Dwa
You'll only hit your head on the windscreen once , then you'll learn how much pressure to apply , lol ;)
