Best coilover options £1000
HG182
  2005 Silver 182
As per title. My Ktec coilovers (not 750MC) have shat the selves as I suspect the plastic grit guards went brittle and cracked off as I can no longer see them! Looking for suggestions for around £1000. Ideally looking at road and track use. Want some full coilovers but the type with helper springs still considered (B14).
HG182
  2005 Silver 182
So the consensus is BC BR from that. Or 750 mc Ktec coilover. I’ll look at both and see what I decide on.
ZachB
@HG182 For under 1k you can get the bc drs with the adjustable top mounts, the only thing that competes with that is used asts
1985michael182
  clio 182
Yes the BC do look good, only thing I found out was the rears aren't a full coilovers. Which will be fine for 90% of trackcars but I'm planning on doing the rear axle strengthening kit so I need a full coilovers. BC DR look very good
