Belts change advice
  RS172
Getting ready to book the 172 in for belts and dephaser, was wondering if it's worth changing the water pump too or is this not going to be needed as such?
Price quoted from Ktec is £761.60 for all belts, dephaser and water pump supplied and fitted
Ol’ Tarby
  Clio 220 Trophy
Two techs in dartford would be closer? I'm sure there's another specialist your way aswell but the name escapes me
  RS172
Just emailed two tech awaiting a response :)
The other was JMS tuning but I think they no longer exist!
  RS172
Is it actually worth changing the water pump? My understanding is its on the aux rather than the timing?
Mine didn't get changed in 2011 on my 51 plate 172 still in good order I would change it if you can afford it it's worth doing at the time
R-Sport.
  Mint 1*2's for sale-
I can do £590 all in
Cambelt kit
Aux belt kit
cam seals
Crank bolt
Dephaser pulley + bolt.
Oil change.
S
-J-
  RS2'ed 172 Cup
S&MWM (Was JMS) are your closest. Call James or Mike to book in
James - 07525 819307
Mike - 07985 266042
  Clio 172
No one has answered the actual question here! Haha iv just booked all mine in for the 29th with Birchdown and have everything but the water pump... Might order one... Hahah.
Alastair.
  986'S 172ph1+182FF
Do the water pump, ive had one destroy an engine and one stupidly loud in the past month. It was that bad the bloke thought he needed a new engine!
  Clio 172
I'm starting to find a few more with issues now.
urrrgh! Don't say that! Haha. Im sure if there is an issue, the lads at Birchdown will see it and let me know! Be nice to have it all sorted and know in my mind that the engine has been sorted for now. :)
Alastair.
  986'S 172ph1+182FF
Just do the water pump, We had a 2 litre mk1 scenic in for a cambelt kit and aux belt kit (same aux belt set-up as a 172/182), water pump was fine at the time, car went away did 2,000 miles and the water pump collapsed, belt came off and went into the cambelt, fuked the engine.
  Clio 172
Oh feck it, I will get one before the 29th then when the car is booked in for! Makes sense I guess since they will be I there doing the belts anyway, guess it means I will need coolant as well... :/ all bloody adds up! Going to spend more than the car cost me at this rate!
  106GTI / NovaC20LET
The water pumps are generally pretty bulletproof but when your spending that much anyway is it worth taking the risk?
  182
Waterpumps are now becoming very problematic. With most knocking on 10years + and just short of 100k it makes sense to just change them.
Mine only lasted to 50k miles:(
  182
The beauty is they are not timing belt driven. So if the become noisey etc its only pum ,coolant and aux kut/belt job so not a biggy.
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
May aswel get it done for the cost of the water pump. Then you know its sorted for a good while to come
You'll be annoyed if you spend that sort of money and then 6/12 months down line its noisy and you have to change pump and aux belt/kit again
