Bad vibration after lowering
  Clio mk3 tce
I've recently put Eibach pro kit springs on my car and now it has a really bad vibration through the full car but not the steering wheel when I hit 60+ mph. We've Rebalanced all four wheels and got them to zero, but now its gotten a lot worse and can now fell it coming through the steering wheel. Has anyone else had this problem with these springs or could help us work out where the vibration is coming from?
imprezaworks
  Mk5 Golf GTI :)
If it wasn’t there before the springs it will be something you have or haven’t done.
My advice would be to check everything is how it should be.
  PH2 172
I`d suggest that you, we & us refit the original springs, & if the problem persists, work out banged it over a kerb.
  PH2 172
I`m considering changing my user name to steve458 as an aspirational choice, better than something172 or 182?
chris blue
  172 Ph1 2001
how you get on OP. Mine had a small vibration, and getting the front tracking done (was way out bcos it has been lowered by previous owner) and that seems to have sorted the vibration
  Clio mk3 tce
We think it could be the alloys, the back two are buckled, and the mechanics at my work said that the Hyundai's that have had the alloys refurbished do the same. As the springs are stiffer than the stock i would feel them a lot more and also the primer, paint and clear coat puts the alloy off on the balancer even thought its been zeroed
