Automatic Xenon Headlight's not working? occasionaly
  172 SPORT PH2
Just dropped my mum off at pub, and the headlights are comming on automaticly ?
What could be the cause... and yes it is dark? where is the sensor on the car?
I thought it was on near the mirror is, but it seems to be for the wipers?
Or you recon a fuse has blown ?
Help
Put car electrics on, but not engine on, turn lights on and off twice twickly and that might solve your problem.
Sure you haven't switched it off by mistake? Sit with your car turned off, turn the sidelights on then off twice and you'll hear a beep, then start the car again and see if they work.
  172 SPORT PH2
put the ignition on and turn the side lights on and off and its should beep twice
BINGO ! done it now guys thanks alot!
I dont know how ive managed to do it like but, im glad thats 1/2 problems solved! another problem is in the audio section if anyone may know the problem ;)
THANKS!!
*SOLVED*:)
