Are these rear RS 172 discs recommended.. ?
  ph1 172
I've been reading up on here regarding f & r replacement discs/pads (ph1 172)
Lots of people seem to recommend OEM rear discs only with OEM pads but i've looked at these, though the image doesn't show the bearing in the discs or the ABS ring ?
http://www.kamracing.co.uk/brembo-h...t-clio-mk2-rs-172-182-2-0-16v-abs-models.html
with these pads:
http://www.kamracing.co.uk/renault-clio-2-0-16v-rs-oem-rear-brake-pads-brembo.html
Regarding fronts, i thought these discs:
http://www.kamracing.co.uk/brembo-hc-front-brake-discs-renault-clio-mk2-rs-172-182-2-0-16v.html
and standard pads:
http://www.kamracing.co.uk/renault-clio-2-0-16v-rs-oem-front-brake-pads-brembo.html
Any thoughts or other pad recommendations ? Not too fussed about uprating stuff tbh.
Greeny.
  440i + 182
As far as im aware you will need to either buy new ABS rings and bearings for those rears, unless you want to use your old ones. I wouldn't suggest using your old bearings but the ABS rings should be fine, assuming they are still in decent condition.
  Trophy #267
its not a case of recommending them, more more cost effective.
OEM come with everything needed and uprating is generally a lot more when not needed unless tinkering with brake bias.
Is one of the few Renault parts which is cheaper and simpler to get from a dealer than elsewhere
  Liquid Yellow 182 FF
Mate, seriously, PM G172 on here, he will sort you right out. I just bought and fitted Brembo HC disks and pads all rounds and I couldnt be happier.
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Brembo rear discs come with bearings
Mintex rear discs come with bearings and abs rings.
I don't list the Mintex in my section as the stock levels are very hit n miss with them.
  ph1 172
Do you have the Mintex ones in stock now & how much are they plz ? Could i have a price also for front & rear pads, & front discs?
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Ta Martin. As said PM is best for faster reply.
I Replied to you this morning Dan, around half 9. Did you not get it?
