amping standard stereo
some amps allow you to use the speaker wire to connect the amp. However even if its just a cheap head unit, GET A NEW ONE!!!!!!!!!!!!!!!!!!!
really would recommend buying a new head unit before you look at upgrading anything else. You never know, you may be satisifed with the sound improvement you will get from a better hu (4x50w), instead of the crap standard (2x20w) stereo.
ive just bought an alpine 7894 I only posted the link as there may be people who want to amp the current headunit for now, as I did ( my amp as speaker inputs) untill i could afford a new headunit. You are right though with just a new HU it did sound alot better, but best upgrade is definatly to add a sub:)
on my New Hu i have an alpine adaptor which means the steering wheel remote bit still works but you only get the clock and temperature.
Alrite guys,
in case yr interested sony do a aftermarket amplifier that plugs into a vehicles ISO connection after the headunit and amplifys the signal to 4x50 watts...available from halfords for £109 quid if I remembers correctly and I should do ....Im a ripspeed specialist! hehe
Just so u know,
David
