ABS fault and brake bias
  Clio 182 supercharge
Hi all, I've got a supercharged 182 cup that has had an abs issue since the first day I picked it up. We have been round the houses trying to fix it but to no avail.
It's not a problem as I have a brembo brake upgrade and abs delete kit with tilton bias valve to install, however it's going to take a month or two to get it installed as we have a few other jobs to do first.
The question I have is what does the brake bias default to if the abs isn't working? And is it safe to use on track?
(I'd like to get a couple of track days in before the brembos and abs delete kit is installed)
Any help/knowledge would be appreciated?
  Clio 182 Trophy
Hi matey,
Depending what has caused the ABS light to trigger will determine the brake bias.
It will either be standard bias with no ABS or 50/50 bias with no ABS.
Be careful trying to figure out which is which 😂🙈
Good luck,
Steve
