1st track day at anglesey
  Clio 172 ph1
Got my 1st track day tomorrow at Anglesey
Looking forward to it I've booked tuition so hopefully that will help
Any 1st track day advice would be great
Knuckles
ClioSport Admin
You’ll have so much fun!
Hopefully the weather is nice for you.
Anglesey is very oversteery in the wet. The left before the pit straight as said being the main contender.
Come in when you feel you’re pushing too hard/being a dick and calm down a bit.
Don’t drive in your mirrors. Focus on your line and the upcoming corner before moving over to let other cars past.
Enter corners there a lot later than you’d think too. It’s very sweepy.
Bed the brakes in well as it’s quite heavy on them in places.
Be mindful of Rwd cars if it’s moist.
28 psi hot.
Check wheel bolt torque. Don’t torque when hot.
Have fun and don’t be a hero
If wet set pressures as above 33/31 and be as smooth on steering and throttle input as possible. If you find the racing line slippery go offline on see if that helps as rubber on the racing line can be slippery when wet.
Once it starts drying up reduce pressures to the above as they'll start to increase the dryer the track becomes. Always do a warm up and cool down lap and remember to leave your handbrake off when just coming off track as the rear pads can bind to the discs.
  Clio 172 ph1
Thanks mate appreciated
