197 on v6 alloys
Knuckles
ClioSport Admin
stole the images from HOLLA, hope you don't mind :eek:
what think?
half way through, i realised... are they even the same fitment?
-J-
  RS2'ed 172 Cup
arent they the same wheels? (raiders) the only difference is 1''
and is that the black one that had the black wheels and it was slammed
I thought the V6 wheels were more 'Spokey' I could be entirely wrong (probably am). IIRC it was a black one, maybe they just suited a black car over red.
Vee
  Mk2 V6 #007
Posting in here so i remember to come back and see the image after i get home (some pics dont come up on my works pc)
The rear wheels may be too wide if anyone did think of doing it? Plus the hassle of trying to find a set, they're like hens teeth and fortune from renault if they could get them (unlikely)!
Knuckles
ClioSport Admin
could you not just buy 17/18'' o.z super turismos in 197 fitment?
  Mini JCW
•Coilover suspension by H&R
•Adjustable TopMount MC Motortecnica
•330mm ktr brake discs (now i'm fitting clio cup discs)
•Carbone Lorraine Rc6 front pads
•Goodridge brake line
•Ate sl.6 dot4 Brake fluid
•Motul 300v 5w40
•Bardahl 75w90 Gear Oil
•Inlet manifold worked
•Airbox Clio Cup/Clio v6
•Air filter Green
•Head engine worked
•Balanced crankshaft Clio R3 250
•Cams Clio R3 230
•Piston Clio R3 250
•Conrods bolts Clio R3 250
•Saenz steel conrods H
•Bottom upgrade engine mount
•Cable throttle Clio Cup/Clio R3
•Steel flywheel
•Reinforced pressure plat
•Quaife differential
•14/69 Couple
•Engine balancing
•Y Pipe (no first cat)
•Cat 200 cells Brain
•KTR Exhaust
•GetData Ecu with 2 map (1 with wideband autocorrection)
•Zeitronix Zt-2 Wideband
•Engine room mapped
•Air Conditioning removed
•Radiator liquid moved, in stainless steel
•OZ Ultraleggera 17” 8j matt black
•Xilema wheels rods
•Toyo R888
•Oil temperature gauge AEM
•Oil pressure gauge AEM
•Steering Wheel Renault Sport
That's the spec list. (Apologies for the thread hi-jack).
  An orange one
Crazy fitment on the v6 the fronts are 7" wide with offset 6, rears are 8.5" wide with offset 68 lol!
As above no longer available from Renault, I've just managed to find a brand new boxed full set so I'm a happy bunny!
Regular OZ superT will be the easiest option, but something in the above pic just doesn't look right to me, prefer the r26 wheels on the 197/200
