182 won’t unlock via Fob
  Ex 182 owner
Anyone come across this scenario.
To clarify.. it only won’t unlock via fob. (All doors affected)
It locks fine with the fob.
It’s starts fine if you get in manually.
All door solenoids unlock fine via dash lock/unlock button.
I would have thought key fob issue would affect both lock and unlock at the same time. It appears my fob only wants to lock the car every time the button is pressed.
Thoughts?
Chris
imprezaworks
  Mk5 Golf GTI :)
Can’t say I’ve come across this before tbh, maybe Carl @bloke has.
I’d try the ‘disconnecting’ the battery trick and see if that sorts it out
  RB Clio 182
Can you touch both battery terminals together for 30 seconds?
Ive heard this clears codes and resets things etc, im unsure how true this is, and i take no responsibility for any damages or funeral costs.
mossyv6
  Trophy,V6,5GT,AG200
Hi Chris, it does sound like a UCH related issue unfortunately :(
With this issue and only having the one key its maybe time to search for a decent complete 2 key ecu/uch lock set.
Going rate is about £100.
