172 Standard sounding exhaust - stainless steel
  Ph1 172.
Hi,
is there anywhere out there that sell a stainless steel exhaust that sounds and looks like the standard exhaust? I've had a search on here and online, but all i can find are mild steel exhausts. I wouldn't even be too bothered if it was mild steel, but not at Renaults prices!
  172 Cup
BTB Ninja, very nice but expensive.
You are probably better off getting a custom 2 1/4" system if you want it quiet, i changed my centre section from 2.5 to 2.25" and it quietened it down a lot. I find 2.5" a little droney on the motorway, but i'm getting old.
  clio 172 cup
Hi Snails, i have a ktec racing stealth cat back exhaust fitted on my 172 cup. Its stainless steel and sounds near standard, it also fits behind the bumper just as the standard one does. I bought the car with a yozza fitted, but for everyday use found this far too loud, so fitted the stealth instead. I hope this helps.
  Ph1 172.
Darklite did a drop in pipe diameter from 2.5" to 2.25" make that much difference? I have emailed a local firm for a quote on a cat-back system. I think I'm getting old too!
I have a K-Tec Stealth at present and i find it too droney at about 60 mph, especially on long journeys. I hoping there is something out there that doesn't break the bank and isn't too loud or droney (for me at least) when driven at motorway speeds.
  172 Cup
I had a BTB stealth 2.5" system, i found it too loud.
I then went to prospeed and had a sports cat/ 2.5" system with a large backbox to keep the noise down, I found this too loud, so charlie fitted a chamber into the backbox, this helped a little.
I then had the 2.5" centre silencer removed and a 2.25" silencer fitted, it is now only a little loud at 78-80mph, then it goes nearly silent, below this, it is really nice.
If i was doing it again, i would have the whole system in 2.25". The sports cat made a big difference to the responsiveness.
I felt no difference with the standard cat and btb system, just made my head hurt and made me feel tired of driving.
Charlie said he wouldn't give up until i was happy with his system, he covered the costs of the mods.
  172 Cup
After i sold the btb, i had the renault system refitted temporarily. It may be restrictive; but it is a pleasure to drive a quiet car if it is a daily.
If i didn't have cams,i would have stuck with the standard system and bought a second hand one when it fell off.
You may be better off trying the standard system with a decat/sports cat first. Mine came off a v8 maserati.
I think gaz kev did this, and i believe he was happy with it.
  Ph1 172.
Cheers for the advice, I will look into how much a 2.25" system will be and how much it would be for just the centre section to me made up. Failing that I'll try and pick up a standard exhaust and replace it when it falls off.
Don
  182 & LY Clio 220 ed
Standard ones will fail...and oem wont be much better. I would use Charlie @ Prospeed as he can do a quiet hum exhaust which shouldnt be much different in terms of sound to the standard.
Go on the website and click on 'sounds' and you can hear the 3 different noises if that helps :)
